Power & Performance
Performance Like Never Before
At Bennington we have 6 performance packages, all backed by the Bennington structural guarantee.
MORE FUN, FRIENDS AND FAMILY
Slice through choppier waters at higher speeds while adding more people to the party. Get your thrill seeking fix without having to leave friends or family behind.
BOAT HAIR, DON'T CARE
Adrenaline junkies unite. The ultimate in versatility, allowing for heavy loads, quick takeoffs for watersports, the ability to maintain higher speeds, navigating challenging water conditions and long distance travel. Do some or all at the same time.
1 + 1 = RELIABLE
No backup is needed when you have two engines. Enjoy a smoother more comfortable ride while exerting less stress on the engines at all speeds and experience better maneuverability when needing to be precise at slower speeds or when docking.
BINARY BENEFITS
Two engines equals more blade area. More blade area equals more acceleration. Corner with confidence at higher speeds while maintaining stability throughout your entire ride.
AN ARMY OF HORSES
The combo of all combos - two engines offering the best in speed and acceleration. Maximize all of the aforementioned benefits for the other twin engine sizes, and add smiles stuck on people's faces for the remainder of the day.
Performance Packages
Bennington offers 6 performance package options. Learn more about each option below.
Elliptical Sports Package-3+ (ESP-3+)
PACKAGE OVERVIEW
- This package is for single engine models rated for up to 600 hp, with twin-engine configurations boosting a maximum of 1,000 hp
- Peak performance and ride quality for 10-foot wide-beam boats
- Patented elliptical tubes maximize buoyancy and stability
- Provides confidence for any conditions you may encounter
PACKAGE SPECIFICATIONS
- Triple 32" wide .125" gauge aluminum elliptical tubes
- Each tube is internally reinforced with stringers and bulkheads
- Sealed versions of our lifting strakes and performance foils, along with a full-length Wavetamer ™ are standard
Elliptical Sports Package (ESP)
Overview
- ESP is designed for higher horsepower applications and rated up to 500 hp
- Top-of-the-line performance and comfort
- Best-in-class stability and maneuverability
- Maximizes water displacement with quick planing and handling characteristics that rival and often outperform fiberglass sport boats
- Two 25" diameter outer pontoons with performance foils, extruded splash fins and .100 gauge aluminum, Wavetamer™ and our patented 32" elliptical center tube with lifting strakes
- Recommended - Power steering and center fuel tanks are recommended upgrades for most configurations
- Optional - For rougher conditions, upgrade to ESP+ with thicker .125" gauge tubes
Sports Performance System (SPS) Package
PACKAGE OVERVIEW
- SPS is designed for 4-cylinder engines 200 hp or less
- Offers handing and performance characteristics similar to ESP in a lighter, more affordable package
- 3 full-length 25" diameter tubes, lifting strakes on the center pontoon, performance foils on the inside of the outer pontoons, solid round keels and under deck wave shield
- SeaStar® hydraulic steering
- 32-gallon transom fuel tank on select models
- SPS+ is for engines over 250 hp with heavier duty construction (upgrades include a composite transom, additional brackets, internal bracing, weld spacing and an aluminum thickness of .100 throughout)
Express Tube Package
PACKAGE OVERVIEW
- Express is designed for 4-cylinder engines 150 hp or less
- More lift and stability, allowing larger groups of people to sit in the bow of the boat
- Additional center tube smoothens ride when hitting larger waves
- Increased bow lift for lighter, lower horsepower engines
- Partial center tube with lifting strakes and wave shield
- Optional - Add SeaStar® hydraulic steering for engines greater than 115 HP (25" tubes required)
32" Twin Elliptical Package
PACKAGE OVERVIEW
- Recommended for smaller lakes and shallow waters
- Allows boat to sit higher and run faster on the water
- Increases boat stability from all sides
- Adds solid round keels and extruded splash fins to each tube
- Each tube adds over 1,000 pounds of additional buoyancy
- Optional - Add lifting strakes and performance foils for even faster acceleration, top speed and improved stability
- Optional - Freshwater and Saltwater packages that include an underdeck wave shield
UNLOCK EXCLUSIVE UPDATES
Sign up for Bennington emails to stay up to date on the latest news, updates and offers.
