Side-view of a Bennington Bowrider cruising at Sunset.
The Bowrider Advantage
Lowering the front of the pontoon allows for enhanced visibility for the driver and a closer proximity to the water for the riders. This creates a more immersive experience for all passengers while elevating the driver's visibility.
Step-Down U Lounge™
CONNECT COMFORTABLY
Connect more comfortably with the step-down U-Lounge. Its lowered position effectively shields the area from wind and engine noise, providing a quieter space for conversation.
Bowrider Features
The V-Hull on a Bennington Bowrider pontoon boat.
Smoother Sailing
Designed with performance in mind, the V-Hull allows for precise handling while on the water. Glide through the water, providing a smoother boating experience for everyone onboard.
Bennington Bowrider Lines
Bennington L Bowrider pontoon boat.
L Bowrider Line
Create lasting memories aboard our L Bowrider Line. Featuring our signature step-down U-LoungeTM, it's the perfect spot for effortless conversation and provides the captain with unobstructed views of the water.
*Ved å klikke på «Send»-knappen godtar du å motta e-poster med reklame fra Bennington. Du kan velge bort når som helst.
Retningslinjer for personvern
