Common buoys
Understanding Lake Navigation Markers
You may have just purchased your brand new Bennington pontoon boat, and are hoping to take advantage of nice weather while it still lasts and do some relaxing pontoon boating. Thousands of inland lakes and waterways across the U.S. welcome boating all along their shores every year, and perhaps you'd soon like to be one of these happy boaters.
If you haven't been boating for quite some time, or are a novice out on the waters, you will notice rather quickly that there are most likely a good number of lake markers and navigation buoys. They're placed here and there along the way to assist boaters in their travels.
The navigation buoys and lake markers assist watercraft operators by directing traffic, marking channels, regulating speed and denoting unsafe areas. In the form of buoys, lights, and signs, in water or on shore, boaters should familiarize themselves with these to aid them in navigation while keeping their journey legal and safe.
Channel Markers
These are all-red buoys (also known as Nuns) and all-green buoys (also known as Cans). These are companion buoys that indicate the boating channel is between them.
When facing upstream, or coming from the open sea, the red buoys are located on the right (starboard) side of the channel; the green buoys will be on the left (port) side of the channel.
If in doubt about your general location, it is recommended you use the 3-Rs approach: Red, Right, Return. Or, the Red buoy is on your Right side when Returning from the sea or heading toward the headwaters of the body of water.
Day Use Channel Markers
Controlled Area (Non-Lateral Markers)
These are white signs or white buoys with an orange circle and black lettering indicating a restricted or controlled area on the water. Very common with these signs is 'Slow- No Wake' speeds, so read them carefully.
Danger
Especially look out for these white buoys or white signs with an orange diamond, with the source of danger spelled out in black lettering. These signs can warn watercraft operators of danger areas such as rapids, dams, rocks, and other hazardous areas or situations. They are also a specific "Keep Out" area marker used in swimming areas.
Inland Waters Obstruction Markers
These are white with black vertical stripes, and indicate an obstruction to navigation. Do not pass between these markers and the nearest shore.
So get to know and understand these markers. They can be invaluable to you in your journeys, and can maximize your fun and safety when out in your Bennington pontoon boat.
